Measuring The Bar Length!!!
how do we measure the length of a bar with 90 degree hook at both ends bars are required for a square footing size 9'-9"x9'-9",bar dia #5,i calculated it as 9'-9" - 2xcover + 2x(12db+pi x 6DB/4), where DB is the dia of bend i.e 3.75" for #5 bar and db is the dia of bar i.e 5/8" .is it ok???
Chapter 12 ACI code explains in detail how you do it. I dont have ACI code anymore or else would have given you the exact reference. Mostly, on commercial projects the structural drawings lists a table that tells what would be length of hook, dia of bend etc.
  • 5 years later...
