Modulus Of Elasticity Of Brick Masonary!!
i have gone through a paper it says that brick masonry has Em=350f'm so there is a great difference . unfortunately dnt have the paper with me at the moment i ll upload the actual lines later.
The values, I given, in my earlier post are from American code. After your comment, I went through a thesis of a Pakistani researcher (doing research in Pakistan), and he recommended to use 350f'm (perpendicular to bed joints) for unreinforced masonry in northern regions of Pakistan.. The value for parallel to bed joint is half of its value in perpendicular direction. It is very conservative estimate and should not used in areas where construction practice is better.
I am attaching his thesis,other Pakistani researchers have also reported similar values.
doct thesis pakistani masonry.pdf
yeah this is the paper i have gone through ,he has taken samples and then chose the Em=350f'm,might there is the difference of material from which bricks are made or the process by which they are baked compared to the american value.about 45 %-50% conservative result is irrational.
It might not be irrational, he has conducted tests and then reported the values. Depending upon the method a preparation of test samples, results can vary hugely.
It depends upon many factors, amount of heat a clay received in kiln, mix ratio of mortar, ratio of of area between two bricks and mortar area, amount of water absorbed by before laying of brick. There may be other issues as well; construction activity needs to be monitored to justify higher values, and it not possible, economically, in those regions.
  • 2 years later...
It is to be noted that the values of modulus of elasticity, recommended in the doctoral thesis referred by baz, are for the brick masonry constructed either in cement:Sand: Khaka (1:4:4) mortar or Cement: Sand (1:8) mortar. Whereas, normally a cement: sand (1:6) mortar is recommended for good quality load-bearing brick work.
I have come across a more recent relevant document, an Indian research paper, in which the researchers have studied the properties of brickwork, carried out using three types of Indian bricks, and three types of cement: sand mortars, namely 1:4, 1:6 and 1:8.  The study also compares the results with materials of  western countries and Australia.
The interesting point is that the modulus of elasticity values of all the tested bricks, are just a fraction of that recommended by Pakistani researcher, for the brickwork used in Northern Areas of Pakistan.
The above-mentioned research paper may be downloaded from the following link:
http://www.ajer.org/papers/rase-2013/volume-1/B120130611.pdf
