Seismic Assessment And Retrofit Design - Masonry Infills and General
Ayesha
Here is an update:
3-Storey Library Building In Karachi.pdfFetching info...
Four Storey Office Building In Muzaffarabad.pdfFetching info...
Stone Masonry School In Abbottabad.pdfFetching info...
Storey Mixed Use Building In Karachi.pdfFetching info...
6-Storey Mixed Use Building in Karachi.pdfFetching info...
And finally a step by step method on how to create and analyse your model.
A_Practical_Guide_to_Nonlinear_Static_An.pdfFetching info...
The attachments are conclusive in manner that they provide extensive informaiton about modelling infills.
For further information related to subject topic, please also visit:
http://framedinfill.org/
  On 6/12/2013 at 3:26 PM, Ayesha said:
I accidentally came across these useful case studies, which, I would like to share. You can use them if you are working on a commercial or residential building retrofitting project. These case studies provide insight about seismic retrofitting and also on analytical methods, that are used for building assessment. I would also like to give due credit to people who are involved in these studies. All these studies were performed under a US-Pakistani Joint Cooperation Project. The details for the project are.
Dear Col. Ayesha Sahiba,
Thank you for the information you have shared, I have gone through, it is useful. I see they have used the in-fill of block walls of 300Psi between the concrete frame structure which is bit similar to the schematic design of our panel, and rest of the frame structure is as normal as we already work with.
However, configuration of our panel is bit different. We aim to have the beams and columns built-in as precast in a composite panel (panel configuration is attached herewith for your ready reference). The structural frame will come readily built-in the panels, each element will be very well connected as described earlier and shown in the attached sections, the slab will be concreted at situ to have monolithic structure. You know that this will increase the quality of construction to the maximum as the panels would be built in the factory under highly controlled environment and erection at site will be done within the provisions made in the panels.
Now, coming to the design calculations and achieving the optimum configuration to reduce the cost as much as possible we are looking for ETABS tool(s) to run as many times it is needed. We again tried to use the same tools which are used to analyze and design that 6-floor building of NED but it gives different results. I am sure ETABS would have such tools, being exert of ETABS if you can help us in this regard, will great.
Once again thanks and best regards.
Aslam
Panel Design.pdfFetching info...
