Error Saving Text File Seprator
asadishaq
  On 6/22/2013 at 10:47 AM, asadishaq said:
Following is the error i encoutered while modelling.how can i rectify it??
Could your tell us about details of the structure? There is no pure frame action in the longitudinal direction except for 1 bay. Is this thing tall?
problem in ur meshing.....Go for auto mesh option...
Secondly ur framing is look quite odd to me....Do u have some restrictions regarding architecturally??
@umar makhzumi: sir this is a G+6 Building not very tall,actually I modelled it using Dxf file and it is giving quiet satisfactory results regarding stability.
  On 6/24/2013 at 8:51 PM, Ayesha said:
Share your concerns ? Why do you think his framing has a problem ?
he is placing his beam at the end of the column, not at the node....as in etab we should move node to node...no doubt in actual a beam can rest at the edge of the column as a support...but in etab we should avoid this otherwise etab will not  consider that column as a support...
Yeah thats a good observation. But Asad wants to model as-is. If he moves the column he can lose his accuracy on other things. Nothing is wrong, structural engineering is like that.
"Structural engineering is the art of molding materials we don't wholly understand, into shapes we can't fully analyze, so as to withstand forces we can't really assess, in such a way that the community at large has no reason to suspect the extent of our ignorance." ...James E. Amrhein - Masonry Institute of America (Retired) LQEngineer (talk) 03:58, 1 September 2009 (UTC)
