Insertion/cardinal Points
Muhammad Abbas
as a whole we dont go in tiny details like adjusting cardinal points....remember that there are 100 ways to pass a failed member but just dont do it..its not practical to adjust each and every beam and column by selecting appropriate cardinal points..just do center to center...struc analsyis is based on center to center..there are ways and means to be on the safer side.. I mean you should limit your interaction reatio for columns upto 0.8 not more than that instead of 0.99...So put more attention on the results rather being lost in model making perfection (like what i used to be in past :P )
  • 7 years later...
