Puzzling System In Aci Code
MarwaLeb
Hello..does anybody have any reference to this topic.. I know it is used in the connection between slabs and vertical elements when the ratio of compressive strength of each exceeds 1.5
Thanks in advance
are you talking about puddling of concrete slab and the column when the ratio exceeds by 1.4?
Please see ACI 318-05 10.15 "Transmission of column loads through floor system"
Please see the attached pdf.
318M-05_318RM-05 Building Code Requirements for Structural Concrete and Commentary (Metric Version).pdf
  • 3 months later...
