Mapped Spectral Response Acceleration Ss And S1 Values
shahidthanvi
Ss and S1 values obtained from GSHAP are Ss=1.13 & S1= 0.45 where as that from USGS OFR are Ss=0.78 & S1=0.224 for  town (Thana District Malakand) out of USA.
Can I input these values in ETABS directly; if yes then which one OR do I need some further calculation based on these values?
thanks for your guidance! Pakistan building code 2007 is based on UBC 97 where as I want to design based on latest IBC code...
Underlying Dataset
SS
S1
GSHAP
1.74
 0.70
USGS OFR
0.92
 0.33
Similar values from multiple sources is not necessarily indicative of small uncertainty, as some of the sources use the same underlying datasets.
Global Seismic Hazard Assessment Program
·        SS = 1.74 g
·        S1 = 0.70 g
These values are rough approximations based on the probabilistic 10%-in-50-year peak ground accelerations (PGA's) from GSHAP. The GSHAP values are multiplied by 2 to approximate 2%-in-50-year PGA values, and then multiplied by 2.5 and 1.0, respectively, to estimate SS and S1.
USGS Open-File Report 2007-1137
·        SS = 0.92 g
·        S1 = 0.33 g
These values are probabilistic 2%-in-50-year spectral response accelerations. Corresponding deterministic values that the International Building Code would use to cap these probabilistic values (where they are greater than 1.5g and 0.6g, respectively), have not yet been computed for this region.
  • 9 months later...
