Slab Corner Reinforcement
in case of torsion at the discontinuous ends of a two way slab it reinforced with torsional steel which is L/5 where L is the longer side,any senior can share the drawing of the reinforcement how that reinforcement is placed ???
its not necessary that you put in 45 degree you can also add this amount in the x and y direction rebars...usually the required area at the discontinous ends will be less and it can easliy be accounted for. If you are designing in SAFE it will automatically include everything in rebar areas or moment contours of M11 and M22 but just remember to add M12 in both M11 and M22 conservatively
i would say to keep it diagonal if "siginifact" torsion is there. The would reduce cracking possibility.
i shared the ref of slab corner reinforcement from the code.here i was having problem to share the images so i shared them on the following link plz check
http://wiki-edupunk.blogspot.com/2012/08/slab-corner-reinforcement-according-to.html
