Safe Mat Foundation
ASAD SUFYAN
Plz explore these questions.
Q1:How to define bearing capacity of soil in SAFE?
Q2:what is mean by the different terms used in SAFE Detailing drawing
like TC,BF,BE,BC etc i think T for top and B for Bottom but the others?
Q3:In SAFE as shown in figure what does the negative shows,if it shows direction
then why it is given Max name to minimum value and Min name to maximum value
for deflection as (Max=-0.068269in and Min=-0.118905in)?
Q4:What is mean by Subgrade Modulus in SAFE and how we will calculate its value?
Q5:For Five storey building my mat foundation possesess Punching shear values as shown so,what
to do with sides although the thickness of mat is 48"?
Q6:I need mat foundation  reinforcement drawing please.
post-1395-0-23138100-1393347592_thumb.pn
post-1395-0-49043700-1393347634_thumb.pn
post-1395-0-07472500-1393347686_thumb.pn
in Safe , you have to provide value of modulus of subgrade, you can't define bearing capacity.
Geo technical report should mention actual modulus of subgrade , otherwise you have to do it on the basis of load and allowable settlement. ( BOWLES - Foundation Analysis and design)
As you have mentioned that you are new in this field, you should concentrate on manual calculations, it would be utter madness if you simply accepted your software results without any manual checks and without any involvement of your engineering.
if you are giving 48 inches raft for 5 storey building, it is too too much ( if it is commercial or residential), it means your loading ( live and dead loads) need correction. verify them from UBC OR ASCE.
Calculate Punching manually first.
AOA,sir how to get service loads (without factored) from ETABS after analysis for footing design.
As we take Pu(factored loads) from ETABS for footing design as shown in fig,Thanks
first define Service load cases as per UBC, then you will get what you need....
Thanks allot for reply.Sir, i have defined, actually my question is that  i have made excell sheet for manuall checks where i need service loads and factored loads , i get factored load from ETABS as shown in above pic by simply right clicking on base joint but how to get service loads....
I have defined all service loads using UBC and other codes.Please kindly  see my sheet where i have pb.Again thanks and bundlls of Prays.
Design of Square footing.xlsx
  • 5 months later...
For Defining Modulus of Subgrade in SAFE see the 1st pic in attachment
As in the figure you uploaded for punching shear results it is clear that u are getting values of the ratio more than 1 which is not oK ..As far as the 5' thickness u have specified for this Raft is too much ..Kindly check the Loadings in ETABs
