Software For Steel Calculation And Design
Muntaha Abid Paracha
  On 3/27/2014 at 4:34 PM, Muntaha Abid Paracha said:
salam
   Is there any software through which we can simply calculate the amount of steel used in a structure.
I believe that by steel you mean rebar. If you generate your drawings through a software, mostly a material take off option is there that reports that information. You can also set up an excel sheet to do the job for you.
