Shear Strength Decreases With Depth???
yeah it is true for deep beams the shear strength decreases with increase in size. Its called sizing effects. Its been proven from concrete research. Deep beams provisions shear is different from normal beams.
there are many factors involved for example the increase in sizes of concrete members and compressive strength the ductility is reduced.
but for normal deep beams the code quation with factor 2 holds good unless you are doing research or desiging a critical member having high shear force.
http://www.ias.ac.in/sadhana/Pdf2012Feb/89.pdf
thanx Rana it is confirmed that shear strength decreases with increase in depth of beams what about the slabs and footings?as in footing we control punching shear by increasing the depth also in flat slabs same procedure is adopted.
yeah in all cases in beams, footings and slabs but mind you this is a research-type thing. You dont have to involve in this unless you are really doing some hifi task. Anyway thanks for your deep interest. I personally like your questions because they are different and to me sometimes difficult to answer. But i love to reply them. You have got a curious mind and i love those people. lets b friends :P
http://www.ias.ac.in...f2012Feb/89.pdf
If there is anything with L/D < 4, it is a deep beam and plane sections before bending are not plane after bending. You need to apply Strut & TIE Model.
Rightly said! University of Toronto has some free softwares that can be used for members having substansial shear deformations.. Shear strength is the only department where canadians are at lead from the rest of the world, considering concrete. I have lots of papers on it. If it interests anyone, please let me know. I can share.
  On 8/23/2012 at 1:51 AM, waqar saleem said:
Thanx @umar sure sir plz share some paper when feasible @ayesha thanx what is L/D and do we use strut and tie model for deep beams only or the phenomenon is applicable in all shear cases???
I will share. For your other questions, see the assumptions of beam design
