Relative Stiffness Of Beams And Columns
Hasan Tariq
If we have 2D single frame .What the etab consider the joint of beam and column .does the beam behave as a simply supported or fixed ?
I am asking this question becasue while designing the houses we have bearing wall structure in which we do manual calculation .but on the beam i used to get confuse how to calculate the moent on them either consider it simply supported or what .Your kind advise is required
It behaves in between simply supported and fixed...depending upon the relative stiffness of beam and column..If column stifness is much more, then the beam would behave as fixed (near to fixed) and pin if column stiffness is very less...
Thanks sir :)
can we have a ratio to compare so to have some direction to follow like how much times the stifness of the column is to consider the beam near to fixed or fixed .?
there is no ratio to compare it.
  • 7 months later...
in case of fixed ended beam, there is no rotation at supports. but when a beam is modeled with its supports on column, then there is rotation at ends of beam because of bending of columns. So this support is not fixed. And not simply supported because beam ends are not fully allowed to rotate as in case if beam is resting on masonry walls. If beam is continue then for approximation u can use moment coefficient method. Other wise u can use wl2/11 or wl2/12 for end and midspan moments as conservative design. You can also model this frame in etabs.
  • 2 years later...
On 3/15/2015 at 11:55 PM, kHURRAM ALI said:
use alignment charts to compare stiffness of beam and column with the help of K value if K value is near to 0.5 it is consider to be fix or if it is 1 then it is near to pin
Can i have the link for Alignment charts? where can i find alignment charts? Are these available at Design of concrete structure by H. Nilson?
