When beam/column capacity exceeded from limit , and we can not increase the column size in that specific direction. now my question is can we change the behavior of a continuous beam to simply supported, by allowing our beam to take all the moments?
(as RCC structures have the capacity to redistribute moments ) need confirmation???
Ratio of flexural capacity of Beam/column is computed to preclude the formation of plastic hinges in columns for obvious reasons, refer to section 21.6.2 of ACI 318-11. Sum of flexural capacities of column at a joint should be 1.2 times the capacities of beam framing into the joint in particular direction. Etabs alerts user when the ratio exceeds; if it does not alert, it means either you are ok, or you have not activated corresponding seismic category (I think it calculates for category D E & F) for which this capacity needs to be computed.
When capacity is exceeded, we can increase the size of column, or reduce the size of beam, or play with reinforcement of members. It has nothing to do with redistribution of moments; If both end of column will yield, during a seismic event, in a particular story, structure will most probably collapse. In a frame, that is resisting lateral loads, you cannot take away the ability of beam to develop negative moment; if you do not provide top reinforcement, it will not be called a moment resisting frame, and  will not resist lateral loads..
Sir,
when you say "Play with reinforcement", what will be the ultimate effect on our structure, specifically on that particular member?
if we just develop less reinforcement of beam in our joint , to fulfill the requirement of "BEAM / Column capacity ratio" , are we justifying the case or we are drifting away from the definition of Moment resisting Frame structures?
It means you need to increase, or decrease, reinforcement in beam, or column. But, You have to have a reinforcement which  satisfies your elastic elastic analysis. You can't reduce the reinforcement, below the level required for resisting factored combos, to satisfy this provision. You need to add more, or reduce. But reduced moment capacity of that member should satisfy the forces of design combos.
If you have provided more reinforcement than the requirement of elastic analysis, you will need to check the shear corresponding to probable moment strengths. Increase in moment capacity of member will lead to an increase in seismic-shear.
I hope, I have answered your query.
Highest moment capacity for a given column size can theoretically be obtained in following ways:
    a. Using a steel reinforcement ratio equal to the maximum permissible steel ratio of the applicable design code
    b. Replacing the concrete with the highest strength concrete, adoptable in given conditions.
Both of of these parameters can be set in ETABS as well as SAP2000. Changing the concrete strength in 'Material Properties' should not be an issue. Similarly, provision of steel reinforcement corresponding to maximum steel ratio may also be made easily by selecting suitable size and number of reinforcing bars, while defining the column sections to be used.
  • 7 months later...
Sir how to activate the feature for alert of exceedance of D/C ratio
  • 11 months later...
would you please answer me, why the column shows red even if the D/C ratio is low (0.136) but the beam/column capacity exceeds limit.
the column section is as great as ISHB 450-1 for two storey building. is it economical.please suggest me.
A.O.A...
While satisfying B/C capacity ratios according to codal limits, is it the right way to use provided steel in the colum section and set the section to "section to be checked"???
As some times the ETABS provides minimum reinforcement in the columns and whil calculating B/C ratios it uses moment against that minimum reinforcement and as the reinforcement is minimum it shows O/S ( over stress).
