Underground Water Tank Walls And Top Slab Load!!!
  On 8/22/2012 at 12:18 AM, waqar saleem said:
How do we consider the weight/load of top slab of a UGWT while we design its walls as cantilever retaining walls ???
conservatively! yes you can design walls as cantilever, but this is not the case always. For example when the walls are much higher like 5 or 6m. Designing it as cantilever will not be judged based on economy when it can be designed as propped cantilever...
Basically if your top slab is not monolithic with your walls as in precast panels placed on the walls for easy removal (due to cleaning, or maintenance) then ofcourse your walls are cantilever. But if your slab is monolithic solid concrete slab you must design it propped cantilever or fixed fixed based on the stiffness of slabs to walls.
Additionally, water tank walls are often governed by crack width criteria (serviceability) not due to strength design.
You can use the document posted by "baz" that lists Two Way Slab/ plates design coefficients subjected to different kinds of loading. I m using this site on my phone warna link share karta. Its in the forum, concrete section most likely. We have used that document to design anything that falls into a 2-way slab. Very Handy
