Ct Value In Etabs
bayan nassar
in UBC97 code there is a different values according to the type of structure .. in both ft and m units ...
in Etabs it is like this Ct(ft) ______
so my question is , do Etabs need to input it in ft units or it depends on the unit system we use ??
Ct=0.035 for steel moment resisting frames
Ct=0.030 for reinforced concrete moment resisting frames and eccentrically braced frames
Ct=0.020 for all other buildings
My question is that the value of ct is dependant on material property like steel structures or concrete strucutures or wooden structures or it depends on the type of frame system like dual frame system IMRF SMRF ?
Ct is the factor which incorporate the material properties and moment-resisting framing system or any other sys. properties along-with x which is power of hn in approximate method of finding building fundamental time period.ref to  ASCE 7-05 sec.12.8.2.1,FEMA-P 751 sec 7.2.4.1
UBC 1997 Section 1630.2.2 relates the Ct value to firstly with material property and then with the structural system.
In materials, only Structural Steel and Reinforced Concrete  are recognized separately. All other materials, are classified under a single category of 'other buildings'.
The structural systems recognized for specific Ct values, are also of two main types; Moment Resisting Frame (SMRF, IMRF etc),  for both Steel and Concrete structures., and Eccentrically Braced Frames (EBF)  for Steel only.
Steel MRF have higher Ct value of .035. On the other hand, Concrete MRF have a lower Ct value of .03. Steel EBF also have a lower Ct value, equal to that for Concrete MRF. All other materials and structural systems have been assigned same low value of Ct = .02.
It may be noted that Ct value is used in the approximate and the simpler method (Method A) of calculating time period T of a structure. The time period value obtained in this way is lesser and conservative, as compared to that calculated using more detailed Method B provided in the same section of UBC 1997.
