Lecture Notes/Comprehensive Textbook: Reinforced Concrete Design by Dr. Wael Hassan
Dr. Wael Hassan
بسم الله الرحمن الرحيم
I provided the book in three formats for easy access in the Google Drive links below
The Full Book in a Single File:
https://drive.google.com/file/d/1gSew3TaAPpEku3tW9fcC4QJ72PaVXBao/view?usp=sharing
Separate Book Chapters Files:
https://drive.google.com/drive/folders/1tueeYgieZx8zWMsmp3g1enoqPyna6Bp8?usp=sharing
Separate Book Subtopic Files:
https://drive.google.com/drive/folders/1ljDq3oRMWCaEz2x-QB5kVNB8GB32d0ke?usp=sharing
Here is another link in Internet Archive
https://archive.org/details/full-book-concrete-design-dr.-wael-hassan-2023
Preface
I have been occupied for long time with the idea of writing a professional textbook on the design of concrete structures that presents this challenging subject in a simplified way, yet technically rigorous, accessible to most civil engineering students, even those not to specialize as structural engineers. I had intended that the book reflects my expertise in structural engineering, specifically concrete design, spanning more than 20 years of professional practice, research, and teaching. With that in mind, I developed over the years sets of lecture notes on reinforced concrete design that I used in various academic roles from teaching assistant to associate professor to teach undergraduate students in higher education institutions in the Middle East and North America
This “book” is intended as a humble contribution in the field of structural design of reinforced concrete to make it more approachable, handy, and useful to undergraduate students and practicing structural engineers. It represents my set of lecture notes on concrete design developed over the period of eight years. However, most of the material presented, especially on the analysis and systems, can be useful in concrete design using any building code, with proper modifications according to local codes, since the theoretical basis used is common in many aspects among various codes
My intent was to wait until I rewrite these lecture notes, with additional formal discussions, in a formal textbook format and assign a publisher to edit and disseminate that textbook professionally. However, given the substantial size of the material and my current academic and professional commitments, this project can take a few more years to be completed in the presentable way I envisioned. I felt guilty to hold back this knowledge further until formal publication although it can help many students and engineers until then, thus I am presenting these lecture notes as is with my handwriting and manual drawings in this “book,” with the intent of revising, upgrading and publishing it professionally in the future. Please refer to the remark in the Introduction chapter for details about the consistency of this book with the latest version of the Egyptian Code ECP 203-2020. The material in its current format is generally self-contained and it helped thousands of civil engineering students and practicing engineers learn concrete design successfully.
I retain my publishing rights of this material for the sole intention of publishing the textbook in a more formal manner in the future; however, I grant the right to any individual to use the book for academic and educational purposes or professional design purposes without my permission. I further grant the right to any individual to post this material as is on the Internet and to distribute as is electronically or in print. The only restriction is to reproduce the material in part or whole in a different format without proper citation to use for commercial purposes without permission.
Wael M. Hassan, Ph.D., P.E., S.E., F.ACI, F.ASCE, F.SEI
Associate Professor of Structural Engineering
TABLE OF CONTENTS
PREFACE
ACKNOWLEDGEMENT
CHAPTER 1: Introduction
Overview
 Organization of the "Book"
CHAPTER 2: Design of Reinforced Concrete Beams
Loads on RC Beams
 Loads on RC Beams Solved Problems
 Straining Actions/Internal Forces of RC Beams
 Fundamentals of Reinforced Concrete Design/Stages of Concrete Cracking
 Ultimate Limit State Design Method
 Ultimate Limit State Design Solved Problems
 Flexural Design of RC Beams
 Flexural Design of RC Beams Solved Problems
Design of Continuous Beams
 Shear Design of Concrete Beams
Torsion Design of RC Beams
 Serviceability Limit States I: Deflection Calculations
 Serviceability Limit States II: Crack Control
 Shear Friction Design
 Design of Short Cantilevers
 Design of Deep Beams
 Problems on RC Beam Design
CHAPTER 3: Design of Reinforced Concrete Slabs
 Design of RC Solid Slab and Beam System
 RC Solid Slab Design Solved Problems
 RC Paneled Beam System
 RC Paneled Beams Solved Problems
 Design of Hollow Block Slab Systems
 Hollow Block Slabs: Commentary for Students
 Solved Problems on Hollow Block Slabs
 Design of RC Flat Plate and Flat Slab Systems
 Solved Problems on RC Flat Slabs
 Design of RC Stairs
 RC Stairs Reinforcement Details and Solved Problems
 Sample Exam Problems on RC Stairs
 Sample Exam Problems and Ideas on Floor Slabs
 Summary Notes on RC Slab Design and Exam Problems
 Unsolved Practice Problems on RC Slabs
CHAPTER 4: Design of Reinforced Concrete Columns
 RC Column Design
 Column Design Example
Column Design Summary and Commentary for Students
 Eccentric Section Design
 Eccentric Section Commentary for Students
 RC Columns Design Tips
 RC Columns Problems
CHAPTER 5: Foundation Design
 Design of Isolated Footings
 Solved Problems on Isolated Footing Design
CHAPTER 6: Design of Reinforced Concrete Frames
Reinforced Concrete Frames Design
 Reinforced Concrete Frames Solved Problems and Exams
 Sample Practice Problems
CHAPTER 7: Design of Reinforced Concrete Halls
 Design of RC Halls: North Light Roof Systems
 Commentary for Students on RC Hall Design
CHAPTER 8: Design of Concrete Tanks and Water Structures
Crack Control of Concrete Structures
 Solved Problems on RC Crack Control
 Design of Rectangular RC Tanks
 Design of Circular RC Tanks
 Design of RC Tanks Rested on Soil
 Solved Problems on RC Tank Design
 Practice Problems
CHAPTER 9: Design of RC Buildings for Lateral Loads
 Design for Lateral Loads
CHAPTER 10: Design of Prestressed Concrete Structures
 Prestressed Concrete Design
 Prestressed Concrete Losses
 Prestressed Concrete Anchorage
CHAPTER 11: Design of Repair and Retrofit of RC Structures
 Cracks in RC Structures
 Concrete Structures Assessment Tests
 Repair and Retrofit of Concrete Slabs
 Repair and Retrofit of Concrete Beams
 Repair and Retrofit of Concrete Columns
أهدي هذا العمل الي أحبائي طلاب الهندسة المدنية والانشائية والمعمارية وهندسة التشييد وزملائي المهندسين و كذلك أساتذة الهندسة الانشائية بالجامعات. أسأل الله أن ينفع به ويجعله خالصا لوجهه. ولا تبخلوا في الدعاء لي ان وجدتم فائدة في هذا الكتاب.
الكتاب يشمل جميع موضوعات تصميم الخرسانة المسلحة بطريقة ميسطة بدءا من الأحمال والنظم الانشائية حتي الأساسات وتدعيم المنشات في أكثر من 2000 صفحة.
لقد شغلتني منذ فترة طويلة فكرة تـأليف كتاب دراسي احترافي في تصميم المنشآت الخرسانية بطريقة مبسطة، ولكنها محكمة من الناحية الفنية، مما يجعل المادة في متناول معظم طلاب الهندسة المدنية، حتى أولئك الذين لا ينوون التخصص في الهندسة الإنشائية. كنت أنوي أن يعكس الكتاب خبرتي في الهندسة الإنشائية، وتحديدًا تصميم الخرسانة الإنشائية، والتي تمتد لأكثر من 20 عامًا من الممارسة المهنية والبحث والتدريس. ومن هذا المنطلق، قمت على مر السنين بتأليف وتطوير مجموعتين من المحاضرات في تصميم الخرسانة المسلحة، استخدمتهما لتدريس الطلاب في جامعات الشرق الأوسط وأمريكا على مدار تاريخي الأكاديمي منذ درجة مساعد تدريس حتى أستاذ مشارك في الهندسة الإنشائية.
يهدف هذا "الكتاب" إلى تقديم مساهمة متواضعة في مجال التصميم الإنشائي للخرسانة المسلحة لجعله أكثر سهولة وتناولا وفائدة للطلاب الجامعيين والمهندسين الإنشائيين. والكتاب يمثل مجموعة محاضراتي في التصميم الخرساني ، والتي طورتها على مدار ثمان سنوات. معظم المادة المقدمة، وخاصة فيما يتعلق بالأنظمة الإنشائية والتحليل، يمكن أن تكون مفيدة في التصميم الخرساني باستخدام أي كود بناء، مع التعديلات المناسبة حسب الكود المحلي، حيث أن الأساس النظري المستخدم مشترك في العديد من الجوانب بين مختلف الأكواد المعتمدة.
وقد كنت أنوي الانتظار حتى أعيد كتابة هذه المحاضرات وأحدثها، مع إثرائها بمناقشات ومواد توضيحية إضافية، في نسق كتاب احترافي واختيار ناشر لتحرير ذلك الكتاب ونشره بشكل جذاب. ولكن هذا المشروع، ونظرًا لضخامة حجم المادة والتزاماتي الأكاديمية والمهنية الحالية، قد يستغرق بضع سنوات أخرى حتى يكتمل بالطريقة التي تصورتها. ولذلك فقد شعرت بالذنب لتأخير نشر هذا العلم حتى ييسر الله النشر الرسمي رغم أنه يمكن أن يساعد العديد من الطلاب والمهندسين حتى ذلك الحين، وبالتالي فإنني أقدم هذه المحاضرات كما هي بخط يدي ورسومي التوضيحية اليدوية في هذا "الكتاب"، مع نيتي مراجعتها وتحديثها ونشرها بشكل احترافي في المستقبل إن شاء الله. وقد ساعدت هذه المحاضرات على مدار السنوات آلافا من طلاب الهندسة المدنية والمهندسين الممارسين على تعلم تصميم الخرسانة الإنشائية بنجاح.
يرجى العلم بأنني أحتفظ بحقوق نشر هذه المادة لغرض وحيد هو نشر الكتاب بطريقة أكثر رسمية في المستقبل؛ ومع ذلك، فأنا أمنح الحق لأي فرد في استخدام الكتاب للأغراض الأكاديمية والتعليمية أو لأغراض التصميم الاحترافي دون إذني. كما أمنح الحق لأي فرد في نشر هذه المادة كما هي على الإنترنت وتوزيعها كما هي إلكترونيًا أو مطبوعة. لكن القيد الوحيد على الاستخدام هو إعادة إنتاج المادة جزئيًا أو كليًا بتنسيق مختلف دون الاقتباس المناسب لاستخدامها لأغراض تجارية دون إذن.
دكتور مهندس: وائل حسن
Book Sharing_2.pdf
    • I am designing a G+2 factory building founded on dense sandy soil as per our geotechnical investigation report.   Load considered:  (As Client was not sure about the purpose of use)  Live Load on Slab= 3.0 kN /m2 Dead Load on Slab= 1.5 kN/m2   (other then Self weight) Grid Spacing: 27'9"x21'3"  Plot Dimensions: 56'x165' Characteristic Load on Columns: (decisive case) Dead Load: 1900 kN Live Load: 950 kN The report recommended bearing capacits: Isolated Footing: 160 kPa at 2.0m depth  Settelment within 25 mm Raft foundation  300 kPa  at 2.0 m below existing ground level (EGL), With the column loads of around 2800 kN and grid spacing isolated footings would require very large foundation sizes leaving little or no clearance between footings and cause overlap issues. Therefore i decided to go for raft foundation.   However, the site condition is such that: The EGL (existing ground level) in the report corresponds to be the site’s current level +0.0 m, while the outer road level is about +0.9 m higher. Our finished factory floor will be at +1.5 m. Now i am evaluating two options: Option A – Construct the raft foundation at the recommended -2.0 m below EGL (per the GI report), then build up columns, cast a plinth beam at the raised level, backfill up to the required ground/floor level, and finally prepare a floor over the compacted backfill. Option B – Raise the site to match the road level using engineered, well-compacted backfill, and then construct the raft foundation directly at the new raised ground level, allowing the raft slab itself to serve as the factory floor. I want to understand: Which option is more technically sound and economical considering bearing capacity, settlement control, and long-term performance? Is placing the raft on engineered backfill (Option B) acceptable practice if compaction and quality control are ensured, or is it safer to strictly follow the geotechnical recommendation (Option A)? Any insights or experience-based advice on this choice would be highly appreciated. Furthermore:  Are the load assumed too conservative? Kind Regards Abdul Malik
