Affect Of Aggregate On Concrete Strength !!!
  On 8/26/2012 at 3:59 PM, waqar saleem said:
aggregates have very high strength but concrete doesn’t what is the reason?
.you cant really say that.. what about the w/c ratio.. what about the distribution of aggregate size ( i mean sieve analysis distribution) what about the mix design of the subject. what about the chemical properties of aggregate?
there are so many things to look for. If you did a test and noticed that.. share the results.
  On 8/26/2012 at 8:37 PM, waqar saleem said:
@umar sir i didn't performed any test but have a ref plz check
http://wiki-edupunk....gy-2e-by-a.html
crush is a rock! and concrete is a composite material made up of different materials. Many factors are involved for example as umar quoted w/c ratio...distribution of crush and their sizes...quality of cement...there is air too in the concrete mixtures then the curing and setting temperatures...if only crush or rock is to be used alone they how they will stick together...so we add cement and water and fine crush to make it a mixture...whose properties are different that the original elements used to make that mixture...
