Seismic And Wind Design Ubc-97
Adnan Rafique
AOA,
I am working on a G+33 Story Building on ETABS and will manually check it but i have some problems regarding the model. Seismic and Wind Analysis is considered but some of the columns on lower stories are failing. I have increased the X-section of columns up to 48" X 48" on lower stories along with i have reduced the torsional constant for columns but no gain. I have attached my model.
Please check my model and guide me.
Dual System.zip
Well, I have not checked your model. But what is the governing combination for bottom columns? It should be gravity. If not then please update us. If it is gravity loading then what is the axial load and Mx and My for any of the 48x48" columns failing? What is the f'c? and fy?
The governing combinations for bottom columns are DCON16, DCON15, DCON14, 13 and DCON11 which include gravity as well as both wind and seismic loading whereas the axial load is PU= 12678 kips, Mx= -5777 kip-in, My= 25862 kip-in. The fc'= 8000 psi normal weight concrete and fy= 60000 psi.I have changed column dimensions keeping in view the moments in x and y directions but still no accurate results.
Please help Waseem Bhai. :)
I guess this building is a hypothetical building. Your compression  and moments are grossly high. Check your material inputs and loads. It is very likely that you have made a unit error in inputting loads or defining materials.
You mean there are 5 load combinations governing at the same time? Please check it again.
Anyway for your loads, 49x49" column will work at higer reinforcement (7.9%). After that every inch increase in column cross section will decrease the reinforcement by considerable amount. 56x56" column will give quite reasonable amount of reinforcement around 3.5%.
But the column size even 48x48" is very unreasonable. For a 33 storey, a square bay of about 9m (30' approx) with ultimate loading of 20kPa (420 psf approx) will give this much axial load reaction at ground floor column.
So do you have 30feet spans? Sure you need improved framing for 33 storey height building. You could use composite columns for example?
  • 8 months later...
