Pre-Heater Tower Of Cement Factory
m_naeem_b
Dear All,
Is there any one who know, how to design Pre-Heater tower of 80m height of any cement factory in ETAB?
Means what type of forces will apply in ETAB?
What will will live laod and dead load apply in ETAB?
what will be the load combination? etc
I made simple model of structure, but didn't load load yet..
I am waiting your kind reply
I did a Google search to see what it looks like.  I am also attaching what I got to make sure that we are on the same page. To design something like attached below, you need to have the operating weight of the machine and pipe-stress analysis report that provides you with stress loads at each location where the pipe is located. You need to make sure that the structure is designed for wind drift less than H/200 and seismic drift less than the applicable code. These structures are very common in EPC Industry. Normally, the vendor provides the maximum operating, empty and hydro test weights along with max shears due to wind and seismic. Ask your vendor for this information and proceed with design.
Please post your follow up questions.
It is not look like as you are thinking. It is concrete structure not steel structure. Yes, I contacted with vendor also. they are saying that maximum of 305KN vertical Dead load and 100KN vertical live load are present in this structure at one story.
I just want to ask that how I apply loading in ETAB. means it is uniform loading in dead load (Static load cases option) or vertical point load.
Because, these tower crossing from slab's opening in the structure.
Before I answer I need a clarification on
Please confirm if this is a free standing structure with an access platform all around?
The picture is not very clear. Let me rephrase the question. Does the preheater tower means a concrete structure that supports different equipment at different levels or it means a tall vessel equipment with offshoots at different levels and a maintenance platform all around as shown?
Regarding load distribution, you should distribute the load as per the actual load path. Point loads would kill design and distributed loads shall be used based on actual lengths tributary to support.
Yes. Preheater Tower that I have to design is a concrete structure that support different equipment of cement industry.
(as also shown in pic that you uploaded in your previous comment.But your pics shows that it is steel structure truss and I have to design concrete structure with same equipment)
