Service Load Combinations For Zone 3 For Footing Sizing
Waqas Haider
Assalam o alaikum,
Dear seniors,
I am to design a two story frame structure in Seismic zone 3. UBC tells me about two SPECIAL SEISMIC LOAD COMBINATIONS. For Zone 1, 2 A, 2B I use ASD load combinations for footing stability design i.e. bearing pressure check, uplift check, sliding check and over turning check. But for zone 3 should i include this special seismic load combinations for footing design also?? Section 1612.4 tells, for both ASD and LRFD the following special load combos should be used
1.2D + f1L + 1.0Em and 0.9D + 1.0 Em...................... for both ASD nd LRFD same combination?? I am very much confused and need urgent reply... Jazak Allah...
Now i m confused about some more things. UBC section 1612.3.1 provides with ASD load combinations i.e.
D
D+L
D + W
D + E/1.4
0.9D + E/1.4
D + 0.75L + 0.75 W
D + 0.75L + 0.75 E/1.4
and for zone 3 and zone 4, two more special load combinations are given.
1.2D  + f1 +1.0Em
0.9D + 1.0Em
Now Section 1630.1.1 tells the following earth quack loads shall be used in load combinations...
E = p.Eh + Ev
Em = omega.Eh
Here Em will be calculated to be used in special load combinations...
And E = p.Eh + Ev will be used in normal ASD lod combinations in place of E.
Am i right??
And if i select option INCLUDE SPECIAL SEISMIC LOAD EFFECTS in ETABS,, will it automatically include this E = p.Eh + Ev?? how can i define 1.2D  + f1 +1.0Em, 0.9D + 1.0Em in etabs??
