Near Source Factors For Quetta
Waqas Haider
Aoa.
As you might be aware, information about Near Source Factors (NSF) for calculation of seismic loads, is given in UBC-1997 Tables 16-S, 16-T and 16-U.
Main parameters required to select appropriate NSF are 'the closest distance to nearby seismic source' in km, and 'seismic source type' (A, B, or C). Realistic values for both these parameters for Quetta may possibly be obtained from National Seismic Monitoring Centre of Pakistan Met Department (http://www.pmdnmcc.net/), Karachi. Geological Survey of America (USGS) may also have this type of data.
BTW...... Two years ago, when I was involved in the structural design of a hospital building at Quetta, (in absence of  some authenticated data) I had used the closest distance to seismic source as 15 kms, and source type as A.
Thanx. i have also taken Soure type A because quetta has suffered many erathquacks of more than 6.0 intensity. But i have chosen distance 10Km just to be conservative. I wil confirm what to take. i will search on references u gave.
