Safe2014 Dead Load Case
ahsun
When I import a raft or slab from ETABS 2013 to SAFE 2014, It is generating dead & "dummy" load case in safe 2014. Load Case, Dummy has a dead load with multiplier of 1. Whereas in Load case Dead, it has a dead and dead_above with a multiplier of 1. When I generate default load combinations from SAFE, it is considering dummy and dead with factor of 1.2. As far my understanding, it is considering double the self-weight of the structure. What SAFE 2014 is doing, is it right? or I have to delete the dummy load case from my model in order to avoid the duplication.
Has anyone faced this issue?
I hope anyone can make my doubts clear.
Well, it should be equal. Are you comparing the sum of reactions on the same load case? You should not check dummy load case. Also you should compare reactions excluding any slabs you are putting in SAFE.
