Assalam o alaikum,
I am to model a basement in ETABS. Basement has 4 side walls and a slab at top. If I model slab as it as at top of walls, it behaves as partially fix support and produces moment at connections between slab and walls. But i want to release this moment.I want my slab to behave as Simply Supported where it connects wall and as monolithic where slab connects with beam and also I want my walls acting as Propped Cantilevers instead of both ends fixed. Also suggest me how to provide same connection in real by detailing of reinforcement.
Jazak Allah.
I want to get real moment forces in shells too. For the time being, positive moments are less and negative are more because of the reason that etabs has modelled slab-wall connection as monolithic. But when this connection will be released for moments, positive moments in slab and wall will increase. I want to model this in such way.
Thanx.
  • 4 weeks later...
For modelling purpose just make the slab very thin (and apply SW manually). Or you can apply small modifiers (no need to apply SW manually then). There will no stiffness from slab and the walls will act as cantilever.
