Tapered Footing In Safe Software
Waqas Haider
Assalam o alaikum.
Does safe has capability to model variable thickness (uniformly variable thickness) footing/tapered footing?? If yes then please explain me how to do it? What I got from internet is We can model variable thickness footing slab by the following method
Draw lesser thickness slab and assign soil springs/required support to it. then draw a 2nd slab with more thickness where u want to thicken the slab. The overlapped area of both footings will automatically get properties of slab with less thickness. (In case of drop pannels it is somewhat different). But this procedure is useful for sudden increase in thickness. How to model tapered/uniformly varying thickness?
The reason why foundations are tapered is because you need a certain depth to satisfy shear and moment at locations of distance d from support for shear and face of support for moment. Beyond these points your numbers are expected to be small and you should always verify BMD and SFD diagrams.There is no point in doing a tapered analysis.
You can draw unit width slabs with uniform thickness. Keep doing it and keep reducing your slab thickness to model tapered footings.
But I would not recommend that for such a problem. FEM is sensitive when thickness changes. So If you reall want to do as accurate as possible modelling (although FEM is still an approximation) you can use other softwares like STRAND7 or LUSAS or any other.
In SAFE I would have modelled it with average thickness (or even less than that based on engineering judgement and specific conditions). You can always develop rationality on any problem with given constraints. Thats creativity you know!
