Finishes Load And Detail
Waqas Haider
Wa-alaikum-assalam!
Materials & thicknesses of floor and roof finishes are specified in the architectural drawings of the building. Load value used for design are based on the specifications of these finishes given by the architect in relevant drawings.
For normal building works in our country however, an allowance of 35-40 psf should be ok for floor finishes. Whereas, depending upon type of roof insulation, a value of 40-55 psf may be adopted for roof slab design.
I use to take 4 inch PCC finishing having load of 48 psf and for load of roof, keeping insulation in mind, I use to apply 60 psf load. In Zahid Ahmad Siddique book, It takes 3 inch pcc+ Tarrazoo and 2 inch brick ballast on intermediate floors.. I m amazed what type of detail would be there at intermediate as well as roof floor?? What is in practice?
Its impossible Architect does not about finishes. Ask him. Its him who will give you FFL level. As umar said finishes will be around 40psf. Here generally finishes including 1kpa min partitions are 3.5kpa for floors and 4.25 for roofs.
