Salam
there is a heavy raft of 6feet depth .Reinforcement is provided at top and bottom.is there any requirement of reinforcement in the middle of this T/B reinforcement for temperature/shrinkage control of this mass concrete.if there is any reference in any code kindly mention
W/Assalam!
AFAIK, there is no specific requirement of providing steel reinforcement in thick rafts, at least similar to your one, other than at top and bottom. Others might be able to help more in this regard.
BTW, why the raft is so much thick? some high rise building, larger spans, or...?
I remember that usual limits of minimum reinforcement do not apply to thick foundations. This is mass concrete.
Depends if you have a temperature control plan and you are using thermocouples to monitor temperature within concrete and sticking to limits. I have done that in one of the recent projects. You should keep in mind  that the mass concrete literature out there is for massive concrete(like dams and stuff) and not for a 6 feet deep raft pour. Just because its a raft pour doesn't make it mass concrete.
Salam
Spans are varying 30 to 90 feet . i am not designing this project  but visited for inspection and observed this.building is -8+G+7.i disscussed this to Imran zafar sab he said that raft concrete is in compression mainly and internal cracks will propagate outwards which will be taken care of by the T/B reinf so there is no need of any reinf at mid level but at exposed faces there should be reinforcement provided.there is no codal requirements
Salam
Shrinkage could be an issue within raft but most importantly, you should be having your structure on piles. I am worried about being it on raft foundation.
Does your building has another buildings around it or not? If not then after some time there is a possibility that someone makes another -8+G+7 right next to your building. That would just make things bad-real bad.
The grade below raft would be subjected to excessive pressure due to your building plus pressure due to adjoining building that was never accounted.
this raft has piles below also i forget to tell.it has some piles 30m deep and some 3m .there is no chance that such building adjoining this building will be constructed in future. is it fine to have such a massive raft and piles?how the connection of pile and raft should be ?
For concrete piles, its easy. You need to embed pile reinforcement into the raft and make sure you provide the proper embedment length for the pile reinforcement.
For steel piles, normally you weld a cap plate to the pile. Nelson Studs are welded to the cap plat. The weld to cap plat-nelson stud is a plug weld. In this case, the connection is checked for capacity against interaction of maximum shear and tension.
