Portal Frame
sulaiman_khan94
W/assalam!
You may use following steps to check deflection of a portal frame in SAP2000 (I am assuming that you are using SAP2000 version 14. Other versions might require somewhat different approach.)
1. Run SAP2000 model of your portal frame, using 'Analyze--> Run analysis' menu option.
2. Select 'Show deformed shape...' from 'Display' menu drop down option. Alternately, you may use F6 function key to display 'Deformed Shape' options window.
3. Select the Load 'case / combo' for which you want to check deflection, and press 'OK' command button. Deformed shape of structure for the selected load case will be displayed.
4. Placing the cursor on one of the member joints, will display deflections and rotations at the selected joint, in length units visible at bottom right hand corner of display window. (You will have to make the joints visible, if these are not already in view.)
HTH
