Modeling Beams
saleem khan
i want to model beam whose ends are resting on masonry wall in etabs,if i assign hinge or roller support to end points of beams how the load,moments and shear will transfer to below elements if it is a mulistorey building
what will be my analysis model for this case.
You need to answer Uzair's question before anyone can tell you what your analysis model shall be- Do you have a mechanism to transfer load from a reinforced concrete beam to a masonry wall in place?
What kind of connection does your beam and wall has?
