Piles As Spring
Salam
Do modelling piles in CSI SAFE as springs is right practice or do we have to model actual piles.which one is better?
any other easily available software for pile design?
what are the critical points for pile design if one is doing peer review?
how the pile cap behave?means how it transfer load to the group of piles.
  • 6 years later...
Please look at the section 4.4.2 of the book: Pile Foundations in Engineering Practice.
Piles can drive their capacity from three sources: lateral support of soil; frictional support from soil; and end bearing. I think you are referring to end bearing only in your query. For most cases, it is the major source of strength for a pile.
Waqar,
For vertical spring values, you need to know deflection of your piles. That is obtained by first calculating load per pile, and calculating the deflection using geotechnical recommendations. Once you have load and deflection of a single pile, you can calculate the spring stiffness by load/ deflection. This is based on un-factored loads. For lateral spring values, geotechnical should provide you the values or lateral k values and you should consider pile group effects. See this discussion:
