Stress Check For Frame Element In Etabs
saleem khan
can i check concrete frame element stresses in etabs after analysis.for steel frame element it is available but for concrete frame element i did not find it.give me suggestions if someone have.
Steel is a homogeneous material and therefore it makes sense to check the stresses.
Reinforced concrete is a composite materiel and it makes more sense to check individual limit states like max moment, max shear etc.
Assalam-o-alaikum!
Narrating, what Umar has said, in another form and in some detail, my comments are as under:
  • From structural point of view, the design information we require (from a manual calculation, or a structural software), is somewhat DIFFERENT in case of Structural Steel and reinforced concrete (RC) members.
  •  In case of structural steel frame design,  we are interested in knowing the 'capacity ratio' (= maximum stress, caused by applicable load combinations / permissible stress) of a member, to decide whether the member has passed (indicated by 'capacity ratio' <= 1),  or failed  (capacity ratio > 1).
  • On the other hand, for the RC frame members, we want to know whether a particular member has failed? (so that its size could be revised). And, if it is passed, what is the required reinforcement ratio / percentage?
  • The failure or passing of a RC member is based on the reinforcement ratio (or percentage). For passing of a member, the reinforcement ratio (or percentage) MUST be within code prescribed limits.
  • For the steel members, ETABS does provide values of capacity ratios DIRECTLY. However, in case of RC members it does so INDIRECTLY by provides required reinforcement quantities / percentages and warning / error messages, to indicate whether the member has passed or failed.
  • A 'passed' member is indicated by 'required reinforcement being WITHIN code-prescribed limits' and 'NO error / warning messages'. On the other hand, a member will 'fail', if the required reinforcement is OUTSIDE code-prescribed limits, accompanied by  error / warning messages, indicating structural deficiencies in relevant respects_shear, torsion etc).
In case of RC Shell elements (slabs, walls etc) however, it is possible in ETABS to check various type of stresses. This can be done using following (ETABS version 9) menu command (for the defined load combinations):
      'Display --> Show Member Forces/Stress diagram --> Shell Stresses/Forces'
      (Select Component Type 'Stresses')
