Slab Elements In Etabs
m_naeem_b
Aslamualikum:
I want to ask that, in ETABs, when we define slab, I put slab thickness same in MEMBRANE & BENDING, is it right or wrong? and what is difference b/w shell,membrane,plate and thick plate? and how and when we use these ? read out help topic in ETABs. But i could not understand.. Can anybody explain me in bit simplest way.?
you are right to put the same thickness in membrane and in bending.
the thickness you put in membrane will give self weight and the bending will give you the bending simple.
If you are using precast panels you can put different thickness in membrane and bending. You can put only the top screed thickness in membrane and slab thickness in bending.
Shell: transfers loads to nodes of that shell element. Like in flat slabs. Loads will go directly to columns. You cannot design beams on shell unless you have meshed it finely. In plane as well as out of plane stiffness
Membrane: transfers loads to beams. It has only inplane forces
Thick plate is used where shear deformations are important but the mesh is simple. Thick plate is generally used when span over thickness is less than 15 for example if slab is 600mm and span is 6m then ratio is 6/0.6 = 10. You can use thick plate option. It has only out of plane stiffness
All this is given in manual helps of CSI softwares.
