Load Bearing Structure Design
Can somebody help me to design load bearing strucutre, BS code is only code writen for massonary strucuture , i am also looking for a book in which load bearing design example are provided, so if somebody have any information than inform me.
Assalam-o-alaikum!
The term 'load bearing structure' is commonly referred to a structure, in which the superstructure loads are transferred to the foundation, through masonry walls. These walls may consist of plain or reinforced masonry. Here are a few good books dealing with design of structural masonry:
1. Manual for Des of Plain Masonry in Building Structures, Institute of Struct Engineers, UK, 1997
2. Design of Structural Masonry by McKenzie, 2001                            (BS & Eurocode 6 based)
3. Structural masonry designers’ manual by  Curtin et al., 2006          (BS 5628 based)
4. Masonry Structural Design by Klingner,  2010                                 (IBC 2009 & MSJC-2008 based)
5. Design of Reinforced Masonry Structures by Narendra Taly, 2010  (IBC 2009 & MSJC-2008 based)
Besides, you may find several other resources on the internet, dealing with design of load bearing masonry structures.
  • 4 years later...
I havent seen a dedicated book for the conventional design of masonry structures. However,  most of the material related to conventional load bearing structure design in Pakistan is summarized in document below
Manual Design of Residential Homes.pdfFetching info...
