Export Floor From Etabs-2013/15 To Safe V14
ayelamayem77
Dear all,
three options are available when export floor from Etabs 2013/15 to safe v14
EXPORT FLOOR LOADS ONLY
EXPORT FLOOR LOADS AND LOADS FROM ABOVE
EXPORT FLOOR LOADS PLUS COLUMN AND WALL DISTORTION
CSI recommends option number 3 when solving under lateral load, please refer to the following link:
my questions
1-if i follow option 2 is it wrong?
2-why option number 3 doesn't have stiff area over column locations? and if i put stiff area is it o.k?
3-an expert engineer has the following opinion on option number three in an older version, please refer to the following link:
does the new version solve that issue regarding the previous link
Dear ayelamayem!
I don't have either ETABS2013 or SAFE2014, so my comments are based on general concepts of CSI software, and with reference to earlier versions of ETABS & SAFE.
Comments on your specific questions, are as under:
1. IMO, yes. The load effects due to lateral loads would NOT be transferred properly and completely, using this option.
2. Yes. You may provide stiff or thicker slab areas under the columns. This is required in most of the cases (due to heavy column loads, and to satisfy shear requirements), and is possible to provide, even in older versions of SAFE.
3. This is a complex issue, and relates to newer versions of CSI software. As such, you will probably need to contact CSI directly for clarification in this regard.
HTH
