Safe - Foundation With Uplift Pressure
rummaan17
Dear Members,
I am trying to model a Raft in Csi SAFE with water uplift pressure applied as a negative surface load on Raft. After analyzing the model, I get negative pressure values which doesn't depict the original condition.
I have been through CSI Knowledge base about utilizing option of "Non Linear Allow Uplift" but my model keeps on doing iteration and doesn't show up any result. Has any body have similar experience in modeling Raft like this.
Will appreciated your help. Thanks alot.
Dont for non-linear analysis in SAFE if you dont know what exactly it is. Most of the times it will keep on running forever.
Here is the trick
Apply soil springs all over the foundations and run and see where you get uplift.
Unlock the model divide foundation such that area with uplift is separated out. Remove springs from that area and run again
Keep iterating like this unless you find zero tension n foundations.
After this, see what is the maximum compression (of course, it will increase). If its more than allowable pressure, increase your foundation sizes and repeat all of the above steps.
And if it happens that you have removed springs from all of your foundations (only a small portion is left with springs) and still tension is not gone, it means the iteration process has failed. Increase the foundations and repeat all steps again.
Dear Mr.Rana and Umar,
Thanks alot for your feedback. I followed the procedure as dictated in SAFE online Video but I was making one mistake that I was putting the uplift case in LOAD CASE in SAFE. For that reason, it keeps on doing iteration but since there is no load from the top it doesn't converge. Alhumdulillah, the things worked out.
Thanks alot once again. I would like to continue one more discussion on SOIL STRUCTURE INTERACTION.
