Corner Window
Engr. Muhammad Adnan
For a composite structure i.e load bearing structure (Residential B+G+1ST)
For the corner window, there is no vertical member i.e column, the beam is supported just on a 9” solid load-bearing wall at the lintel level i.e below the slab at the door level, is this arrangement of cantilever beams works??
  • 4 weeks later...
