Sway Options In Etabs & Maximum Deflection
Dauntless
Assalam o alaikum
1. I want to ask how ETABs considers the sway conditions in concrete frame design?  I designed an RC structure in which most structural members fail but when I change the preference  to sway intermediate most of them pass the design. Is there any way to define prior to design for IMRF input?
2. What is the maximum allowable deflection for an RC structure? As in codes it  is usually mentioned for structural members but not for the whole structure like at top story for seismic design.
1. You can check in ETABS analysis manual pdf about these things. These options enforce reinforcement limits according to the selected category. For example if you select sway intermediate/special, ETABS will check for reinf limitations given in ACI chapter 21.
2. Codes explicitly state that, please read again UBC or ASCE. You will find the limits of 0.020/0.025 for seismic. For Wind read commentary of wind chapter at the end of ASCE 7-05/10. Usually the limit is H/400 but you must know on which W to check this limit. Is W service or ultimate. Read about it in the same commentary chapter.
Otherwise, you can check this article.
Always search the topics before posting a new one. It helps us.
Type of moment resisting frame to be used, depends upon the seismic zone or category of the area in which the building is located, as permitted the applicable design code (UBC, IBC etc).
In ETABS, you may select the 'sway' type for applicable moment resisting frame system (e.g., 'Sway special' for SMRF, and 'Sway intermediate' for IMRF etc.), from  Preferences, BEFORE starting analysis of your structural model.
I will just add one more thing..
Type of sway frame depends upon what kind of lateral force resisting system you have.. Moment frames will sway.. braced frames or shear wall system would be non-sway frames. Regarding "sway intermediate" and other terminologies, you will have to see how Etabs defines them. What I have stated is the generic structural definition.
Thank you so much for the guidance. Sir Umar Makhzumi, yes sir I have shear wall system may be thats why ETABs is not giving an option for sway preferences before the  analysis. But after design when I right click any element then in overwrite option there is sway and it is as sway special, and if I change it to sway intermediate then most of the elements pass.
Another problem is that I am having a very high deflection for my structure, it is about 20 inches at top story, can you please suggest what changes should I make to reduce the deflection. The area of my structure is 100x100 sq feet, zone 2B, 21 story, soil type SD and I want to do static analysis.
To select sway option before analysis,
select all elements by Ctrl+A, then goto Concrete Design Preferences from Design menu, and select VIEW/REVIEW overwrites and then select the second checkbox and change the sway option.
Remember that, you have to do this each time you add or change your model. All new members will be set to default and you have to change them too like this.
What is the height of building, around 220 feet? This 20 inches sway is on wind or seismic?
Add more stiffness to building to reduce it, add more shear walls, increase length of shear walls, etc.
"select all elements by Ctrl+A, then goto Concrete Design Preferences from Design menu, and select VIEW/REVIEW overwrites and then select the second checkbox and change the sway option."
this option worked for almost all the beams. Thank you
Sir, my structure is 3 basements + ground + 17 stories, total height 252 ft but above ground it is 202 ft. And the 20 inches sway is seismic.
You can see the following topics to calculate your allowable displacement/ drifts. If your displacement is greater than what is required, check your input and add more shear walls.
http://www.sepakistan.com/topic/1341-ubc-seismic-drift-limits/
http://www.sepakistan.com/topic/109-building-drifts-in-etabs/
I think there is no absolute max requirement for overall building drift for strength seismic zone. All you have to check is inter-story drift.
For wind yes, there is this usual H/400 requirement where H is the overall building height. And in your case it is 202x12/400 = 6.06" = 6" (Use 0.7W to check drift here).
You can also check human comfort criteria and acceleration at top floors.
Yes 20" seems excessive, and you must put more strength and stiffness to your building. The building is very flexible.
