Beam Or Column To Design
mhdhamood
Dear all;
How to decide if shall I design the section as beam or as column.
because as we know the horizontal element (beam) may also have axial force in addition to moment.
like a column. I mean is there a limitation for the value of axial force to be neglected and then we deign as beam ?
Dear in normally earthquake resistant structure, it is not common to have large axia forces in the beams. So you do not need to check all members. Just for your own satisfaction you can check few beams.
But if there are Transfer Girders or Beams connecting to tapered columns, beams supporting columns, then you need to check the axial force. In this case, in ETABS, you can just design that beam as column by providing in the section properties P-M2-M3 design
Muneeb
i read an column design by BS 8110 and dont understand why the how etabs caculation the moment design : Mi, Madd.
M x and My design
Can someone help me to understand this, i in Viet Nam,
You should refer to ETABS design manual.
Yes you need to check each member, if axial force is more than the limits in code, you design it by P-M-M interaction (like column design) other as beam design (only for 1 direction moment + torsion + shear).
But as Muneeb said, you can have an idea what type of loading is and what forces are experienced by members.
