How To Define Wind And Seismic Loads In Staad Pro
shani2k2
Thanks a lot my problem is that i am modelling a simple T-support(2.6 meter high and .225m at both side at the top) while wind definition i calculate as per AISC which generate wind intensities from zero to 4.5 meters
now when i add wind load and give verical range from zero to 2.6m(ht of support) i get warning wind load cannot be generated, so i make the vertical from 0 to 4.5m(intensity of second point in the intensity table) the load is assigned this is confusing.
second point is for seismic definition what do i add one is self weight , etc
Your problem is not clear. In order to get proper advice, you will need to provide some more details about your structure, in addition to attaching some pictures of your model here. The additional details should include usage of structure, geometric details, applicable loading conditions, and specific references to design code sections & tables  you are referring to.
