2D-Plate Analysis -Safe
mhdhamood
Dear Engineers;
Is it allowed to use the 2D-plate analysis for the raft??
Because the 2D neglects the inplane forced of the raft, Will it affect the out of plane forces??
if yes then I think it is not accurate for the analysis in presence of earthquake and wind loads coming from the superstructure, Am I right??
Or it just will neglect the results of analysis of in-plane forces without affecting the out of plane forces.?
Plate elements by default consider shear deformations. If you use shell elements, then then would ignore the shear deformation. I think your question should be that Is the analysis using Shell Elements is correct for deep rafts as they ignore shear deformations.
  Quote
Either model core wall above as beam element when 2D plate analysis option is checked or use default option where all dof are activated (recommended) and assign appropriate lateral restraints to few footing/mat corners to stabilize your model especially when running nonlinear uplift analysis. That's why we always export walls above as beams from ETABS to SAFE.
https://www.linkedin.com/groups/2983130/2983130-6279435049549074433
