Smeared Crack Models
Fatima Khalid
Anyone can explain what is smeared crack models? Fixed or rotating models?
I have searched on google but I couldn't understand what exactly they mean. If any one can explain in simple way or refer any book which can help me understand the cracking models and their behavior.
Thank you
Following document, especially its Section 2, might help you understand basic concepts related to the discrete and smeared (both fixed and rotating) types of crack models:
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=11&cad=rja&uact=8&ved=0CF4QFjAKahUKEwiC7a6lwe7HAhVBfhoKHdR6Bnk&url=http%3A%2F%2Fheronjournal.nl%2F34-1%2F1.pdf&usg=AFQjCNFt3L2jfuZECxkPEl8Byl-S9sQUBQ
Looks for these documents on the web for the literature of the subject topic.
  • computational  strategies of masonry structures by Lourenco.
  • computational modelling of concrete fracture by Rots.
  • Elasto-plastic multifixed smeared crack model for concrete.
  • Building response to ground movements by Holger Netzel.
Smeared crack models are models for explaining tensile resistance of cracked concrete, or masonry. Fixed and rotating refers to the ability of crack to propagate along a fixed axis, or at an angle to the axis of previous crack.
 If you know the direction of propagation of crack you can use fixed crack model; if you dont, then rotating crack model should be used.
