Bottom Steel Placement Of Slab At The Junction Of Beam
What is the correct location of bottom steel if we have an upstand beam on slab? Most of the time the steel runs through in slab so shal we run it over the top of bottom steel of beam or below the bottom steel of beam?
Remeber the cover is usually change in beam and slab. In slab we usually we have 0.75 in cover and in beam we have min 1 in cover.
What do you guys say about it?
Placing beam steel at top of slab steel would be better as we have more flexibilty to meet cover requirment. 1 to 1.5inch. For an upstand beam t-beam action would be at slab-beam junction so slab would act prettey much as part of beam and a reduced effective depth for beam can be compensated by slab steel.
I will agree to this!
