Verification For Concealed Beam Design
Waqas Haider
Assalam o alaikum,
Dear seniors,
Recently i had two design a concealed beam for a case where, A slab of Lounge of dimensions 18 ft x 28 ft is to be designed. The slab is resting on walls o all 4 sides. I broke the span of slab in between and converted it into two panels of 14 ft x18 ft with a beam spaning in 18 ft direction. Slab is of 5 inch thickness and 4 inch thickness finishing. So Total debth of concealed beam i can provide is 9 inch ( 5 inch + 4 inch). Total factored load that comes out to be acting at slab area is nearly 0.22 ksf. I designed this concealed beam with dimensions 24 in width and 9 inch depth. The steel i provided is 10 # 8 US bars at bottom and 6 # 8 US bars at top of beam through out. The design philosofy i followed is that i designed for moment wl2/8 for 9 inch depth and steel required came out 8 # 8 bars. a secion of 24 x 9 in2 can take just 4 #8 bars as singly reinforced section ( i.e. p.max). I had to provided 8 # 8 bars so I provided 10 # 8 bars at bottom and 6 # 8 bars at top ( to balance extra steel provided in bottom so that compressive strength of section equally get increased as tensile strength is increased in excess of rho max) and designed ad doubly reinforced beam. The stirups i provided is #4 @ 6" c/c 2 legged...... Can any one of you confirm me this design?
Thanx.
Concealed beam is not a beam. Formula for trapozial load distribution is based on the assumption that your beams are atleast three times as deep as your slabs(I dont remeber this correctly). Concealed beams may reduce deflection where they are provided but providing concealed beam doesnt divide your slab. Slab/beam depth ratio is important in dictating behaviour.
You designed a 9 inches deep beam for 18 feet span. Nine inches does not satisfy deflection criteria of the code (ACI-318).
The thickness of your slab is based oin 18ft x 14 ft dimensions of slab, which is not enough as far as deflection-control is concerned; the beam will deflect more than the desired limit which will result in un-desired deflection of slab.
Thats not a beam, its just a local stiffening, it will bend with the slab. You should design the whole panel as one with all sides resting on walls. You are going to have huge deflections as its simply supported on very stiff walls with no continuity! Think about hordi/waffle slab system if columns cannot be provided.
4 inch finishes? thats huge!
Dear Waqas
There is no such thing as concealed beam in Engineering design. No book or any code has defined it... this concept is basically originated from the labor/lay man who basically dont know the exact philosophy of beams.  Let me clear the confusion.. Flat plates are structures which do not posses any beams. The main issue in flat plates is the punching shear. So in order to counter the punching shear, U shaped stirups are provided in the slab reinforcement along the critical section. When u look at the final reinforcement of flat plate slab, this stirrups seems like a beam of depth equal to the slab. Due to the visual symmetry, many lay man and contractors thinks its a beam. so they name it a concealed beam..
Remember !  these stirrups are only provided to counter the shear and no flexure capacity is there, but most of the engineers even dont know about this.. I suggest u better go for proper frame structure or design the flat plate. Hope that clears ur confusion...
