Retro Fitting Of Steel Stairway For Emergency Exit
shani2k2
After the earthquake of 26th october , our attention went to emergency  exit steel staircase which by no means can be termed as safe
plz see the attached report.
the main cols have been placed on earth without any foundation
steel members are under size
members are not straight .
can this be retrofitted ?
how?
waiting anxiously for a solution by so many good SE engineers lets see who has the knowledge to do it!!!!!!!!
ZeeshanASSESMENT REPORT OF EMERGENCY STAIR CASE OF BUILDINGsepak.docx
Here are my two cents:
Steel structures are comparatively easier to retrofit. However, you will have to determine
- the locations where you need strengthening,
- how much strengthening is required?
- how this can be done?
- whether it is economical (as compared to complete replacement)? , and
- will the structure, in retrofitted form, be visually acceptable?
This can be done by modelling the existing structure in ETABS or SAP2000 etc., using member section properties as per actual section sizes, and a suitable steel grade (using best and safe judgement, based on quality and physical condition observed at site). Apply all applicable code requirements  (as per IBC, AISC, ASCE etc,)  and observe stress levels of various members.
Now, after saving the model with a new name, upgrade all the failing members with larger or alternate member sizes (to which these can be replaced or upgraded by structural additions/modifications).
Comparing the results of the two structural models, mentioned above, will give you a clear idea about where the retrofitting is required, and to which extent.
In case (after the above analysis, and working out relative costs), it is determined that retrofitting will be economical (rather than complete replacement) and visually acceptable as well, it (retrofitting) may involve replacement of or additions/ modification to various existing members. Required connections may be made using welding or bolting, whichever is appropriate.
how?
Zeeshanattachicon.gifASSESMENT REPORT OF EMERGENCY STAIR CASE OF BUILDINGsepak.docx
One of the worst Emergency Exits that I have seen. What company do you work for?
Major challenge with retrofit here is that the all members are significantly undersized and connections are not up to mark. Connection capacity is likely to be signifcantly low. There is also a question on the workmanship of Abid Welder. I would scrap it.
  On 11/4/2015 at 4:46 AM, shani2k2 said:
@AYESHA..
this was not constructed or design by us , its the work of  Abid Welder, and i have to make this so called stairs safe for use and approval is to be taken from the abid welder like metality
So whats the outcome from your company ? I don't see retrofitting viable here.
