Damage In Stone-Masonry After Seismic Event
Badar (BAZ)
I recently visited a residential building, located in Kehal area of Abbottabad. The visit was made to visually-inspect the building in order to ascertain if the building sustained any structural damage due to the 7.5 magnitude earthquake that jolted many parts of the country on 26th October 2015.
The structure is a single story stone-masonry building with mud plaster on walls. The roof of the building consists of wooden rafters, purlins and C.G.I sheets.
I am attaching photos to show you the damage sustained by the buiding due to the seismic event of 26th october.
It is stone masonry so it has ruptured during the shaking its joints at different location, crack at the corner of door seems critical and also wall joint at the corner has opened a bit. any other jolt can be of serious threat as far as these two location are concerned.
The cracks don't look that bad to me. One question would be how old the building is? Was the building there when the 2005 October Earthquake hit? If yes then is there any information about damage to structure during the Oct 05 Earthquake. Just thinking out loud. I still think diaphragm should be provided. Can't really get my head around the wooden truss.
(Umar Makhzumi) The cracks don't look that bad to me.
Nor to me, keeping in view the fact that Abbottabad is in seismic zone 3, and as the pictures indicate, wall height is not less than 12 ft.
It appears that the workmanship during wall construction must have been very good, as the walls have resisted the earthquake jolts in a much better way, not expected from common stone masonry buildings constructed in our country, ordinarily.
