Special Seismic Data Input In Etabs
Shahzad Ali
Special seismic data in ETABS, is used for the enhancement of normally calculated seismic forces, in specific conditions as required by Division IV of Chapter 16, or Chapters 18 through 23 of UBC-97.
Inclusion of special seismic data, results in the use of special seismic load combinations of UBC section 1612.4, for the design of structural members. Parameter 'Em', used in these special load combinations, is described in section 1630.1.1 of the code.
Generally, special seismic load effects should be included in ETABS models, for all those structural elements for which the code (UBC) requires the use of special seismic load combinations of section 16.12.4.
According to Division IV of UBC Chapter 16, special seismic load combinations are to be used in following cases, among others:
a. For elements supporting discontinuous systems, as described in Section 1630.8.2.
b. For collector elements, splices, and their connections, in accordance with Section 1633.2.6.
