Query about progressive collapse and redundancy
Mahnoor Khawaja
i have read this line; i have understood the whole sentence and concepts of the terminologies used in it except continuity. can any one explain what's meant by this " structural continuity"?
The underlying principles involved with progressive collapse are redundancy, continuity and ductility.
A progressive collapse is a catastrophic partial or total structural failure that ensues from an event that causes local structural damage that cannot be absorbed by the inherent continuity and ductility of the structural system.
If i understood your question correctly then your above statement states that progressive collapse happens due to
1. lack of redundant elements
"A redundant or indeterminate structure has more structure than is absolutely necessary. "
2. lack of continuation
Simply supported beam vs 3 span beam. Which one has better moment redistribution?
3. lack of ductility
Shear wall system vs moment frame. Which one has better ductility.
Redundancy and continuity are interrelated. However, continuity might not be a good thing in certain cases. One example of that would be where you have T or L -Shaped building in high seismic zones. Continuity in such cases could result in significant torsion. The statement posted is a "sweeping statement" and interpretation varies across different cases. There is no right or wrong answer.
