How To Calculate Story Stiffnes In Etabs?
asadishaq
  • 6 years later...
  On 1/7/2013 at 8:22 PM, UmarMakhzumi said:
Story Shear/ Story displacement
Umar bhae shouldn't be it story forces instead of Story shears ???  and the denominator as absolute maximum displacement of floors.
  On 1/9/2013 at 8:03 AM, asadishaq said:
In ETABS's show response table , why story stiffness is always zero?
kindly tell me
If you are using ETABS 2015 or higher version then Go to Analyze tab > Set load cases to run > tick or activate the option for "Calculate Diaphragm Center of Rigidity"
You have raised a good point. Generally stiffness is applied force/ displacement for force required for a unit displacement.
For seismic or any lateral loads, the loads sum up as you go from top to bottom. For for top floor, the stiffness is:
Force at top floor/ displacement
However, for the level below, the stiffness would be:
Sum of Top Floor and level below lateral forces / displacement of that level. :)
Let me know if this is still not clear and I can provide another example.
Cheers!
Cheers!
Its looks a bit strange. Actually i have been using the story forces from ETABS summary report and not the Story shears for finding this story stiffness thing. It would be better if you can elaborate it with some example to clarify my thoughts. I have the understanding the as we are taking the absolute floor displacement and not the story displacement in the stiffness calculation and this displacement should be because of the story force and not the story shear which is sum of forces coming from all above stories
Shear is generally resultant for force at a given point. Like beam shear is sum of all forces at a section.
Similarly Story Shear refers to the net lateral load at a floor. ETABS might be defining story forces as net forces at a level and story shears as individual seismic shear for each floor (the opposite way). They can define it how they want, as long as they are referring to the same concept.
Displacement has to be absolute as we are interested in stiffness. If you were interested in any serviceability limit state, then it could be relative for that limit state. But for stiffness, its absolute to base.
Thanks Umar bhae for the explanation. i got your point very clear now. il definately gona look in to ETABS help to confirm what it means actually by Story forces either the absolute value or net value at a given floor level.
I checked and found that in ETABS 9.7.4 version after analysis when you export the summary report, it gives you Story Forces under two different heading which are as follow:
1- Auto Seismic Story Forces (Fx, Fy, Fz) >> Here Fx and Fy  are the individual seismic shear values at each level or absolute seismic force values at each floor level.
2- Story Forces (P, Vx, Vy) >> Vx and Vx are the sum or net values (Story shears) and ETABS uses these (Vx and Vy) along with the total floor displacement for calculation of story stiffness
Thanks once again Omar bhae ...
  • 5 months later...
Sir, for checking story stiffness manually we will use Story force ( Vx or Vy ) or Auto seismic forces (Fx or Fy) from etabs ??
Hamza i checked and confirmed from ETABs higher versions that its the story shears Vx or Vy we have to use for calculation of story stiffness
Sir i have gone through SEAOC manual book for ubc-97. In example 4 of manual they have solve a problem on story stiffness by following formula (Story displacement/height of story) then check the it with code provision.
