Modeling Pits In Raft
rummaan17
Dear SE Pakistan Members,
I am trying to model pits in Raft in CSi SAFE. PIT Bottom slab is depressed 2m below the Top of RAFT. I have following concerns which I would be glad if anyone can address.
1- What is the criteria/condition to analyze raft slab at one level (continuous) and pit/ raft on different level.
2- What is the appropriate method to utilize in SAFE to model RAFT with Pits.  I came across option of Vertical offset in SAFE and the other is to model wall at periphery and model slab at bottom.
Generally, we model same raft thickness below PIT depressed at 45 degree angle . For this reason, I always modeled PIT on same level as that of RAFT. (See Attached Pic for RAFT Plan & Section of PITS).
post-1668-0-44519500-1454506467_thumb.jp
post-1668-0-89823800-1454506470_thumb.jp
I think you are fine modelling raft at one level. I am not an expert on this.
Regarding
I am not clear what do you mean by "Model wall at periphery and model slab at bottom?  Periphery of pit?
