Etabs Reinforcement
Beenay Shahi
well i designed a residential building in etabs which is two bay in both x and y direction. actuall 4 bay in y direction including two bays of very small span of about 5 ft.
the bays in both direction is of about 12ft. its two and a half storey. Its pretty much a average normal residential rcc building. all columns are 12"x12" m20 concrete.
beams are 9"x14" m20 concrete. slab is m20 5inch thick. reinforcement is hysd grade 500. live load in all rooms 2 kN except in the staircase slab and balcony slab which is 3kn and floor finish for all floors 1kn. wall loads in exterrior walls without opening is 9.09km/m. wall loads in exterior walls with openings is 6.36kn/m. interior walls 3.51km/m. paraphet walls 2.18 kn/m. eq load according to indian code zone v seismic area.
but etabs gives very little reinforcement for my columns. and reinforcement on all columns are same. its 743mm^2. I have remodelled it and redesigned it in etabs for at least 10 times but same result. Its a recent problem in etabs 2015. sometimes back it used to give the practical reinforcement in columns. I don't know whats the reason for the wrong result in etabs. for such a residential building the reinforcement area for middle column should have been 1600mm^2 and for the edge column 1200mm^2 and for corner columns 900 mm^2. Please somebody check my etabs model and help me find whats the matter. is it something wrong with my model or its software?
bouse for Mr. Rupendra Bista.EDB
Without looking at the model I can confirm that there is nothing wrong with the software, check your inputs, check detailed design of columns by right clicking on them. Check the unsupported lengths and see if they are correct. Also check the meshing point of slabs with columns if they are properly carrying any load.
If possible upload detailed design of the column failing/giving more reinforcement here instead of model.
If the resultant column reinforcement is equal to the minimum reinforcement, as required by the applicable design code, one possibility is that you might have erroneously assigned 'supports' condition to all the beam-column joints, instead of the joints at base/foundation level only.
