Value Of R
Dear Friends
Salam
I need help on the designing of a building structure. I have two existing stories of RC built in 70's. New structure is going to be built on its roof i.e one story. This new extension will be cold-form or hot rolled or mixed.  I have some problems in defining EQ data form.
How the value of R will be selected for this type of structure. I have RC frame for first two stories and extension structure columns are hot rolled HSS (Hollow Box), trusses are of cold form steel. What do we call this system. In Building Code of Pakistan table 5.13  different structural systems are defined but i could not reach any of them.
W/Assalam.
According to BCP Table 5.13, R value for an Undefined Structural System should be selected as per procedure given in BCP Section 5.29.9.2. However, IMO the problem may be tackled in the following manner, as well.
In case structural details about the existing RC structure are not available, it may be considered as an Ordinary Moment Resisting Frame (OMRF) at the most, with a tabulated R value of 3.5.
On the other hand, third storey, proposed to be constructed in steel (cold-formed or hot rolled) may be assumed & designed as Steel OMRF (R = 4.5), Steel EBF (R = 5.6) or Steel SMRF (R = 8.5). However, in absence of reliable structural information about the existing structure, it would not be advisable to design the third storey for a higher R value, than the RC structure supporting it (the third storey). In such a case you may assign an R value of 3.5 to whole structure, to be on the safer side.
However, in case you do have exact or reliable structural data for the existing structure, and you are satisfied that it can be classified as an IMRF or SMRF, you may use a higher R value for the whole structure, including the additional storey.
I hope that before proposing the third storey, you would have already checked that the footings are capable of taking the load of the additional storey safely.
HTH
